compression test perkins
8njohn
05-19-2007 18:01:34
Will be testing in next few days. What should the compression be in a perkins diesel ad3.152? My manual says that their shouldn't be more than a 10% difference, but it says nothing about what the pressure should be.
Thanks
DavidP, South Wales
05-20-2007 10:38:55
 Re: compression test perkins in reply to 8njohn, 05-19-2007 18:01:34
Hi, Useable pressures can range fron around 240 to 320 PSI. A guide is anything in excess of 250 PSI is good. As you have mentioned, it is not so much the pressure more the variation that is important.
DavidP
