1505 has the shakes
carsw
05-20-2007 21:55:49
I removed the pto drive out off the tranny on my 1505 this spring and replaced the injection pump at the same time, now I have a vibration in the tractor over 1500 rpms it shakes the hole tractor when going in high gear,not so bad under load in field, what would cause this or were do I start looking
david1505
05-21-2007 14:23:42
 Re: 1505 has the shakes in reply to carsw, 05-20-2007 21:55:49
yes,I would check that front coupling for proper engine to transmission alignment first,more than likely that is your problem.There is a special tool for doing this but it is not as accurate as would be rigging up a dial gauge.I had the same trouble with mine and got it pretty close with the tool,a machinist suggested the dial gauge afterward.good luck.
holm1155
05-21-2007 08:26:12
It has been quite a few years since I worked on one .If I remember correctly you had to remove the drive coupler between the engine and the trans.That is the first place I would check.
