MF 200 Crawler
BAHoman
05-22-2007 22:00:44
My 1976 MF Crawler/loader has a hydrolic reverser. When it first starts up, it runs great. After the reverser gets up to operating temperature it starts hesitating to move from one direction to the other. If left in forward (or reverse) it will run all day long, until you go to neutral or try to change direction. Then it just sits there as if it's in neutral. After the trans cools down, you can get on it and run it again just like it should,,,,, ,until it gets warmed up again.
Is there no one out there that has a clue to what my problem might be?????
Any help would be greatly appreciated
marlowe
05-23-2007 14:55:29
 Re: MF 200 Crawler in reply to BAHoman, 05-22-2007 22:00:44
have you checked the torque converter oil leval
B.A.Homan
05-23-2007 19:55:16
 Re: MF 200 Crawler in reply to marlowe, 05-23-2007 14:55:29
I appreciate your reply. I actually, after all I've been thru, have not checked the torque converter. I just assumed that since it will run all day in one direction, that it probably wouldn't be an issue. Perhaps you're right. It definitly won't hurt to check it.
Thanks
BA
marlowe
05-23-2007 20:04:10
 Re: MF 200 Crawler in reply to B.A.Homan, 05-23-2007 19:55:16
do you know how ???
B.A.Homan
05-27-2007 09:31:24
 Re: MF 200 Crawler in reply to marlowe, 05-23-2007 20:04:10
Yes, I have manuals.
Thanks, it was a quart low, however turned out to not be the problem
Thanks
B. A.
