will a loader off 135 fit a 165?
Brian08
05-23-2007 09:32:29
Will a loader off 135 fit a 165?
Brian08
05-24-2007 05:09:30
 Re: will a loader off 135 fit a 165? in reply to Brian08, 05-23-2007 09:32:29
I figured out its a Dunham-Lehr #22 loader
135 Fan
05-23-2007 16:00:07
It depends on the loader. If it's a heavier loader it will probably work. If it's a lighter loader you're asking for trouble. Dave
brian08
05-23-2007 16:54:15
 Re: will a loader off 135 fit a 165? in reply to 135 Fan, 05-23-2007 16:00:07
I went and looked at the loader tonight I dont think its a massey it was white and had a 22 on the side it has a single cylinder for the bucket. Its a big loader to big for the 135. Its also a quick attach the mount is a large metal pan that bolts on the under side of the tractor and has a grill guard. It also bolts on the front of the tractor.
Do you think this will bolt right to the 165? Sorry I couldnt get any pictures.
DavidP, South Wales
05-24-2007 00:54:14
 Re: will a loader off 135 fit a 165? in reply to brian08, 05-23-2007 16:54:15
Hi,
I believe that the simple answer is no. Besides any weight issues, does the 165 have power steering? If part of the frame is attached to the front of the tractor, ie front axle casting then it will not fit a 165 without modification.
If it was mounted on the bolts under the gearbox and at the fender points then I believe that those dimensions are the same for both tractors.
DavidP
Brian08
05-24-2007 04:50:18
 Re: will a loader off 135 fit a 165? in reply to DavidP, South Wales, 05-24-2007 00:54:14
The mount looked like a skid plate basically the tubes for the rear of the loader mounted right before the floor boards. The front mounted I would say around the bumper. I may be able to get the mount from the fellow to try but its about 1 hr away from me. The loader is a good price at 700 bucks.
