Smoking 180
Bret g
05-25-2007 08:51:16
I have a mf 180 that produces alot of whiteish color smoke when i start it up, is that normal? what can i do to fix it? Also on the same tractor, the power steering is not working, it was real low on oil when i purchased the tractor. I filled the resivoir but it didn't seem to help, any thoughts?
DavidP, South Wales
05-25-2007 12:46:38
 Re: Smoking 180 in reply to Bret g, 05-25-2007 08:51:16
Hi,
Remove the thermostart starting aid which is screwed into the inlet manifold. Look for any signs of the coil and inside of the inlet manifold being 'wet' with fuel. That is a frequent problem. Do you have hydrostatic or mechanical PAS? If its mechanical make sure that the spool valve is being actuated when you initially turn the steering.
DavidP
