1080
Bryan MIplantma
05-31-2007 12:37:22
I have a MF 1080 that I lost high in the trans and the remotes and the pto all at once, any ideas what it might be?
I believe that I will be removing the cab that is on this tractor to split it. The cab is very rough!! I would like to find a nice orginal to replace it with, maybe one with air and heat?
Any help would be great!!
BigMarv1085
06-06-2007 14:16:38
 Re: 1080 in reply to Bryan MIplantman, 05-31-2007 12:37:22
Bryan, my 1085 which is close to the 1080 had the big hose come loose inside of the tractor and I lost pressure. I also burn't up my PTO cluch pack.
Bryan Miplantman
06-03-2007 12:01:48
Big dean your link is not working for me??
Big Dean
06-01-2007 04:39:54
Bryan It may have also busted one of the lines inside. There is one running through the transmission to the front and the line from the pump to the independent PTO.valve
DavidP, South Wales
05-31-2007 12:43:58
Hello,
Thinking as a general reply to this problem I think that you may have lost drive to the pump which powers High trans, PTO and the remotes. The plated drive unit is held onto the Ferguson pump on some models by special circlips, these do fail.
If you are able to remove the hydraulic cover you should see where the problem is and hopefully not have to split the tractor.
DavidP, South Wales
