MF 180 PTO
Alfred
06-04-2007 15:19:30
I have a Massey Ferguson 180 with multi power, that I just bought. The PTO won't engage at all.
I took the tractor apart and checked the main pump and lines. They are all fine.
Any suggestions before I take it to a tractor repair shop?
Bob N.Y.
06-04-2007 16:43:37
 Re: MF 180 PTO in reply to Alfred, 06-04-2007 15:19:30
Does your tractor have the 2-stage clutch or independant pto?
BigMarv1085
06-06-2007 14:09:04
 Re: MF 180 PTO in reply to Bob N.Y., 06-04-2007 16:43:37
Sounds like you need to adjust the 2 stage clutch. There should be a plate with 4 bolts in it at the bottom. Remove and you will see the 2 discs.
Rednick
06-16-2007 15:50:38
 Re: MF 180 PTO in reply to BigMarv1085, 06-06-2007 14:09:04
My two stage would not engage and it was the pin close to the transmission in the PTO lever linkage was worn enough it would not put into gear.
