MF 1085 Aux Hyd
Beachlimousin
06-09-2007 16:22:56
MF 1085 history: PTO quit on the previous owner and he had it repaired. When he got it back the aux hyd did not work. We bought it at auction.
I get 900 psi at the side of the case and about 800 at the quick connect. I removed the lift cover and did not find any thing obvious. The manual shows two pressure relief settings. Could the low pressure relief be keeping the pressure from going over 1000 psi? How does the aux hyd switch to the higher 2300 psi? Am I on the right track?
NEIADan
06-10-2007 20:13:29
 Re: MF 1085 Aux Hyd in reply to Beachlimousin, 06-09-2007 16:22:56
I am no expert as to the details of the 1085. We purchased one with 700 hours on it in about 1980. Spent over $10,000 in repairs on the thing over 3 years finally had to have it drug on a trailer with less than 1100 hours. Hydraulic selector valve body cracked and bled through from on outlet to the other. May be your problem. The tractor used a piggy back pump that was connected by steel lines inside the tranny. The vibration caused them to brake. Several thousand in labor for $40 dollar line. (happened twice) Final straw was when the trans input shaft broke losing hydraulics and movement. Good Luck
