333/30K Block Questions
John in OK
10-04-2000 01:51:41
We have a 333LP that probably needs a block. Found (have not looked at) a 30K Parts tractor. Could the block be the same?
Thanks for the help
John in OK
Don
10-05-2000 14:06:27
 Re: 333/30K Block Questions in reply to John in OK, 10-04-2000 01:51:41
the two engines are very different, but the 162 flat head will bolt into a 33, so I would guess it would go into the 333. the prop shaft might be a different length.
Alberta Mike
10-04-2000 13:48:05
Not a chance. The 30's had a flathead Continental engine in them (valve in block) of probably 140 or 162 cubic inch displacement. The 333's had a 208 cubic inch displacement BUT also they were an overhead valve engine. The 333 engines were also made by Continental I believe but you'd never know it because it did not show up on the engine anywhere (like it did on the little flatheads of earlier years).
Don L.
10-04-2000 07:42:27
NO....they are very different. I have a 33 block for sale that woold work. $200.00, Austin Mn.
ph 507 433 0073
