150 hyd system
Bryan Bell
06-17-2007 07:10:24
Recently purchased a 150 with a hi-lift on it. The control valve is between your legs on the top right of trans. The hi-lift won't go up if the 3 point hitch arms are in the up postion. Whats up with this? The slide selector on the right that normaly works the 3 point does nothing. One of the hyd cotrol valves { there are 2 } works the 3 point.Is this the nature of the beast or is there any thing that can be changed
Big Dean
06-17-2007 16:56:22
 Re: 150 hyd system in reply to Bryan Bell, 06-17-2007 07:10:24
When the lift reaches the set position the position control lever is set for the rockshaft cam neutralizes the control valve and the pump stops pumping. If you move the quadrant position control lever to the right into constant pumping you will have power to your high lift.
