1950 MH Pony Implement Questions
Dave Bryant
10-06-2000 07:53:31
I have a Pony with a harrow, disc and plow. I believe the plow and disc attachments are missing some linkage peices. The harrow has a straight bar welded to the long shaft with chains on each end. I assume the chains bolt to the hydraulic lift arms and the front of the long shaft attaches to the bottom of the tractor in the middle. I also have two fingers that are on the hydraulic bar for belly type attachments (I think).
I cannot figure out the hook up for the plow and I believe some of it's peices are missing. I also have some lift extensions with a bar and some type of screw "jack" that I assume is for the plow angle, depth, etc.
Can anyone provide me with a reference to see 1) how this stuff attaches and 2) what parts I may be missing. A picture would be great. Also, did Massey Harris offer a snowplow for the Pony. If so I would be willing to pay a good price for one.
I would also like to convert the Pony to 3-pt if possible. Are there any conversion kits available? I have only had this tractor for a week and it runs good. Needs some new wiring and radiator work, otherwise it runs great.
I think this is one of the best looking tractor ever made. Is there a club for Pony owners?
Please help,
Dave
Dave Bryant
10-09-2000 10:06:41
 Re: 1950 MH Pony Implement Questions in reply to Dave Bryant, 10-06-2000 07:53:31
Thanks for the reply. I spent some time with the tractor this weekend and figured out the plow hookup. I also was able to purchase a used snow plow and will retro fit it to the tractor using the posted advice.
Some minor repairs to the plow, harrow and disc and I am set. What a treat this little tractor is. Someday, it will look and run like new. Then time for another, maybe a MH 22 or 44. Would also love to have a MF 35 gas.
All I need to do now is make her purr. I am looking forward to turning some soil in the spring.
All the best to the best of all.
Dave
Robert from Quebec
10-06-2000 14:21:56
I have a Pacer which is a slightly bigger brother to the Pony but I had a Pony for awhile too and some of the implement parts are interchangeable. To put a moldboard plow on you have to turn the drawbar around bolting it so that it faces forward under the rear axle. You hitch the front of the plow to the drawbar via a clevis to pull the plow. To raise and lower it there is an arm that bolts to one of the extension arms that extend out the back of the tractor. At the end of this arm is a notch into which you hitch a chain, at the other end of which is a big metal ball which sits in a ring. The plow floats and when you raise the arm the metal ball meets the ring and lifts the implement. Mine actually works very well.
For a snowplow I have a home made rig that I've used for almost twenty years with the Pacer and I've never pushed snow more effectively: The snowplow extends out the front. Two metal shafts (the shape of I-beams) lead back under the tractor and hitch at the very back - to a hole drilled in each of the sidearms that hold the draw bar, one big bolt on each side. The plow pivots up and down on these two rear mounted bolts. TO raise and lower it, weld a short chain on each of the two shafts at a point under the belly of the tractor directly under each of the arms that you control from the seat. Attach it to these arms with a bolt so that you can remove it at will. As you can see I am not a very good technical writer but I don't know how to put a picture on the internet and don't have a camera anyway. It's too bad 'cause this is a nice little rig. What I like most is that even though you can't angle the blade, the tractors are so small and turn so tight you can place the snow easily. Get a set of chains and build a box to sit on the back that you can put weight in. (You can use the box around the yard in the summer.) These are a great little tractor and easy to fix. Power to weight they will match anything going.
