wiring diagram
beaver
07-02-2007 20:07:35
my g-pa has a mf deluxe 50 gas withg side dist mount it died on him and we have replaced the coil the solenoid and have rerun all the wires cant get it to work was lookin for a wiring diagram if someone has one please or can tell me what im doin wrong
MowerBoy
07-05-2007 05:56:49
 Re: wiring diagram in reply to beaver, 07-02-2007 20:07:35
Check the interlocks(Brake/Clutch, Blades) also fuses.
todd p
07-03-2007 16:43:19
check your fuel
beaver
07-03-2007 19:08:46
 Re: wiring diagram in reply to todd p, 07-03-2007 16:43:19
plenty of fuel no fire on starter side of the solenoid and have fire on neg side of coil
Ty Tower
07-03-2007 01:38:54
elec goes from pos bat to dist ( hotwire ) .
in dist set points at 14 thou when you open points they should spark weakly or its not insulated.
when points open short current goes through coil to earth ,when points close collapsing field in coil gives high voltage surge to centre of dist
when set turn over motor with centre wire from coil about 1/4 inch away from good ground .It should spark strongly every time points open & close
