MF50 Running Poorly, Black Smoke Solved
Aaron Ford
07-04-2007 08:52:06
My brothers MF50 started good, idled fine, and did well as long as no work was expected. As soon as the governor called for power, it would die. All work had to be done in low range. It had been running rich, but I dialed the fuel back and she ran clean and crisp, but no power when the throttle was opened more than a quarter. Pulled the carb and found a broken choke stop and a broken choke spring. It was running on 3/4 choke. Gonna order the parts when finances permit.
Also have a problem with the hydraulics only raising 1/2 of what they should. No chain bind, but no full lift. The tractor started life as a high clearance model, but was later converted to standard. The lift arms do not look like they are going high enough. What do y'all think? Thanks Aaron
