MH30Regular
Lift Arm Length and Attach Point
Abe Bunker
10-18-2000 10:10:33
I have now installed the hyd cylinder and
the lift mechanism to my new 3PH system. Can anyone tell me the total length of the
lift arms and the point of attachment to the tractor. Also the size of steel I should use for
the lift arms. The two 12.5 X 4.5in sideplates that hold the
drawbar support are attached and I removed the
drawbar and the support for ease of working, but I need to know where to attach the two 7/8 pins in
reference to the plates. I was thinking of simply
torching out a hole in each plate and welding in a 7/8 rod straight through. 3PH engineering says that the pins must be
installed at the designed pull point, in this case
drawbar height. That leaves me with a problem as
the attachment point for the drawbar under the housing is approx 2in in height below the bottom edge of the plates, or is that insignificant. I have 12.4 X 28 tires. Any help would be appreciated.
