Ferguson 300 combine stuck in gear
Chris95
07-28-2007 17:06:43
This combine has sat for 10 years or so. It is stuck in gear so I can"t start it. Don"t know if the clutch is ceased up, I suspect it is, or could there be another problem? If anyone has had a similar experence I would like your input.
wmw
07-28-2007 20:41:34
 Re: Ferguson 300 combine stuck in gear in reply to Chris95, 07-28-2007 17:06:43
I ran a 300 for several years, the clutch would freeze in a couple of months if I didn't push the pedal down and put a bolt thru the hole in the assembly thats then under the floor(to keep it down). I would think that the transmission is under tension and a frozen cluch is preventing you from getting it into neutral. Do you have the 208 diesel Perkins?
chris95
07-29-2007 04:17:32
 Re: Ferguson 300 combine stuck in gear in reply to wmw, 07-28-2007 20:41:34
No, its the gas
