Worked my axle housing loose...check it out
Case450
08-02-2007 12:11:11
third party image
I have a backhoe mounted on this 274 thats WAY too big for it. I basically use the tractor to carry the backhoe around but never EVER push/pull/lift anything with the tractor when the backhoe is attached because of this reason. My dad and brother were using the machine last. Obviously they thought I was overreacting when I told them to take off the backhoe before using the tractor. Now look at the fun I get in 34 degree heat!! (I'm from Canada)
Case450
08-02-2007 12:11:59
 Re: Worked my axle housing loose...check it out in reply to Case450, 08-02-2007 12:11:11
third party image
Just another pic
Case450
08-02-2007 12:15:24
 Re: Worked my axle housing loose...check it out in reply to Case450, 08-02-2007 12:11:59
third party image
Another pic where you can see the housing seperating.
