Part numbers
Dennis (VA)
08-06-2007 06:48:15
Trying to rescue a found in the woods tractor. Does anyone know the part number for the hydralic filter mounted behind the grill on the MF 202? No dealer with in miles of here. So a NAPA number would be great too. Have the available manuals (except parts, lost ebay bid) but none lists part numbers for maintenance items. Also can you still get type A transmission fluid; if not, what is a substitute? Thanks for all of the help
Dennis (VA)
08-06-2007 17:54:05
 Re: Part numbers in reply to Dennis (VA), 08-06-2007 06:48:15
Tom Thanks!
Tom Dold
08-06-2007 11:34:34
Dennis
I believe the filter you are looking for is MF part # 191855M4. It depends on the serial number of the tractor. You can use Dextron II or Dextron III in place of Type A.
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349 605-772-4541
dold@alliancecom.net
