MF 85 wide front conversion?
bmwrider
08-21-2007 05:35:37
I need to know if you can convert a norrow front 85 to a wide front. If so, what parts are all required?
John - Central NY
08-21-2007 17:01:07
 Re: MF 85 wide front conversion? in reply to bmwrider, 08-21-2007 05:35:37
You will need a high-arch front axle from an 85 or a Super 90.
Tom Dold
08-21-2007 13:41:08
bmwrider
Yes
The front pedestal unbolts from the steering spindle and then the steering arm for the wide front bolts to the spindle. The front main casting is the same on all the models. You will need the steering arm (bellcrank) the tie rods and the wide front. The wheels and hubs should be the same. The Suoer 90, 85 and 88 should be the same.
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349 605-772-4541
dold@alliancecom.net
Bob N.Y.
08-21-2007 16:32:16
 Re: MF 85 wide front conversion? in reply to Tom Dold, 08-21-2007 13:41:08
I think the 88 would have a straight, non-adjustable front axle and cast center wheels.
