Massey Super 90 crank shaft
cfs
08-21-2007 13:21:51
What would cause the crankshaft to break behind the number one piston on a perkins diesel?
Tom Dold
08-21-2007 13:27:19
 Re: Massey Super 90 crank shaft in reply to cfs, 08-21-2007 13:21:51
cfs
A bad engine balancer. Check to make sure the balance weights are tight on there shafts and that the bushings are good in the balancer housing. The balancer also has to be timed correctly to the crank shaft.
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349 605-772-4541
dold@alliancecom.net
