Massey Harris 444 weak hydraulics
Bill Guarino
08-26-2007 14:53:33
I own a Massey Harris 444 and while using the front end loader a shaft in the hydraulic pump broke so i replaced the pump with a used one and the pressure has never been the same...is this just weak pump and should i look for a different one or what. Also there should be no blockage in the lines as it was a clean break and the filter is changed regularly. I'm quit confused with this.
p.s. if anyone has a good used pump im interested.
thanks much
marlowe
08-26-2007 16:06:02
 Re: Massey Harris 444 weak hydraulics in reply to Bill Guarino, 08-26-2007 14:53:33
ya weak pump . you can change the shaft from the weak one and put it in place of your broken one part interchange on most of the pumps. you will need a press DO NOT HAMMER THE SHAFT OUT. if your old pump was strong i'd change the shaft
Bill Guarino
08-26-2007 16:31:01
 Re: Massey Harris 444 weak hydraulics in reply to marlowe, 08-26-2007 16:06:02
By changing out the broken "impeller" shaft with the weak one my understanding would be that the pump would still produce a weak output. if i understand correctly i think i just need another good used pump...is there anywhere you would suggest looking for one
marlowe
08-26-2007 17:06:43
 Re: Massey Harris 444 weak hydraulics in reply to Bill Guarino, 08-26-2007 16:31:01
change just the shaft from the weak pump and put it in your old pump the shaft will come off the gear thats if your old pump had good preasure.
marlowe
08-26-2007 17:29:54
 Re: Massey Harris 444 weak hydraulics in reply to marlowe, 08-26-2007 17:06:43
i did NOT word that right when i said the shaft will come off the gear i did NOT mean the drive gear that will NOT come off you have to take the pump apart and remove the gear in side the punp from the shaft. lay every thing out on clean paper so you get it back together in order
Bill Guarino
08-26-2007 22:40:10
 Re: Massey Harris 444 weak hydraulics in reply to marlowe, 08-26-2007 17:29:54
OHH ok i understand much better now. i also looked at the old pump and that helped me some to. thank you marlowe for the advice...i understand completely now and that should be a pretty quick fix and will also save some much needed money thanks again
