Update on the 175 loaner
Bret4207
09-02-2007 17:36:50
Thanks for the help guys. So far I've determined the tractor doesn't have the 2 stage clutch. The alternator or battery seems weak and only the oil pressure gauge works.
The bad news is the hydraulics. If I rev the engine it'll just barely lift a 6-700 lb round bale. It won't hold it there without leaving the tractor revs up or using that lever down between your legs that directs hydraulics to 3 pt or remotes. I can lock it up with that. I figure it needs a rebuild on the pump at least and maybe some valve body adjustment or a rebuild.
They want $5800. I figure I'll offer $4500. and ask for parts at their cost plus shipping. Currently the tractor is about as useful as a souped up Farmall M with live pto, IOW- who's gonna want the equivalent of a bareback 63 hp tractor? I'll mention it could be a 50 cent o-ring or a $1500.00 pump. Worth a try I guess.
DavidP, South Wales
09-03-2007 03:52:44
 Re: Update on the 175 loaner in reply to Bret4207, 09-02-2007 17:36:50
Hi,
In the UK a non-gen auxillary pump suitable for the remotes and IPTO can be purchased for around £400-450 (800 to 900 dollars?).
A new non-gen Ferguson pump complete would be around £700-800 ($1400-1600). These pumps can generally be repaired.
If they bite at $4500 its still a big gamble to take and there may be other problems as well. Why not get them to give you a price for the tractor and repair in full working order?
Cheers
DavidP, South Wales
