Oil on brakes - Massey Ferguson 165
BillD
09-04-2007 09:37:52
Had no brakes so I opened up the rear axle and found the brakes soaked in oil due to the oil seal failure.
I am told that this is a common problem with this tractor. Where can I get new seals that will work?
Aaron Ford
09-04-2007 13:22:44
 Re: Oil on brakes - Massey Ferguson 165 in reply to BillD, 09-04-2007 09:37:52
I got mine from my local tractor parts house. I believe Porter8n on ebay sells them as well. Not expensive. Bad seals and a plugged drain will oil down the brakes. An overfilled belly will soak em too. $6 a peice I believe. HTH Aaron
