3 point hitch ( hop )
James
10-31-2000 16:15:10
I have A M/F40 industrial tractor. When I bought the tractor it had no lift arms. Installed all new parts. And now it hops up and down two or three inches, when its not all the way down. It does this with or without implement installed. What should I try now?
Jack in NB
11-01-2000 01:13:40
 Re: 3 point hitch ( hop ) in reply to James, 10-31-2000 16:15:10
James -
We've had this problem with a loose master spring behind the top link attach point. 1/8" slop here can transfer inside and cause the lift arms to cycle.
Usually occurs with an implement on, and attached to the top point.
With no implement, it may be slop inside in the control linkage.
The I&T manual for the 35 and up covers early system adjustments, and the 135 manual covers the later systems. (Early systems are roughly identified with the regular injection - vertcal injector - engines, and the later systems go along with the direct injecton - slanted injector - engines.)
