Massey Harris 30 Three point hitch kit
Christian Hendr
09-07-2007 12:06:47
I have a 1952 Massey Harris 30 and I would like to put a three point hitch conversion kit on it but I am unable to find one on the internet. Does anyone know where I can get one?
passthebuck
09-16-2007 17:55:08
 Re: Massey Harris 30 Three point hitch kit in reply to Christian Hendrie, 09-07-2007 12:06:47
I too have a massey harris 30 & am in need of a 3pt hitch set up as well. We should buy in bulk! I"m in Manitoba.
massey333
09-07-2007 13:25:18
IF your tractor has Hyd.on it now(some 30s didn't),see if you can find a hitch for a 33 or44 because they have the same rear end(as far as mountings go).
Christian Hendrie
09-10-2007 10:04:50
 Re: Massey Harris 30 Three point hitch kit in reply to massey333, 09-07-2007 13:25:18
Thanks for the feed back. I was't aware that the three point hitch from a 33 would fit the 30.
massey333
09-10-2007 18:27:30
 Re: Massey Harris 30 Three point hitch kit in reply to Christian Hendrie, 09-10-2007 10:04:50
OK,maybe I made it sound too simple,I was thinking after market kits where you would have the corect LIFT assy.If you try going orginal equip,then make sure get the correct Cyl.and rockshaft for it,because what you may have now WON"T WORK.Good Luck with your ideas.
Christian Hendrie
09-10-2007 12:08:08
Does anyone know where I might be able to buy some good used three point hitch parts for a Massey Harris 33 in Minnesota or Wisconsin?
