Marvel Mystery Oil
Briar Creek Sta
09-07-2007 21:02:34
Just thought I would pass this along.
I run an injector cleaner in my 1135 now and then as sort of a preventative maintenance on the injectors and injection pump.
The cleaner I normally used wasn't in stock when I stopped by to pick up a can. They really didn't have much on the shelf that would be ok to use in a diesel engine other than a can of Marvel Mystery Oil. I figured, what the heck...it worked ok on my gas engines and claims to work as well with diesel.
I've got to say, after adding that to a tank of diesel and mowing for about an hour, that tractor ran smooth. I would dare say I never heard the tractor run that smooth since I got it. It didn't seem to have that typical 1135 black smoke either.
I didn't exspect to see any change at all in the way the tractor was running. Not sure if the additive did anything or if it was all in my head.
Anyone else out there try the stuff in diesel? Any luck with it?
TomTex
09-08-2007 13:01:28
 Re: Marvel Mystery Oil in reply to Briar Creek Stables, 09-07-2007 21:02:34
Hey Briar Creek, I bought 2 quarts today and will see if my results matches yours. Tom
Briar Creek Stables
09-08-2007 18:41:24
 Re: Marvel Mystery Oil in reply to TomTex, 09-08-2007 13:01:28
It will be interesting to find out if you get the same results.
I bought the diesel the same place I always do. Just seem to run alot smoother than usual after I ran the haybine for about an hour. Still running smooth today, not sure if it's all a coincidence or this stuff actuall works.
