independant massey fitter needed in south wales u.k
tony vobe
09-09-2007 09:09:08
any fitters who work or worked on masseys who knows the industrials v well and live near me in south wales u.k
i have excellent facilities but no knowledge on agri vehicles. i can help and strip anything ready.
tony vobe
09-11-2007 14:06:09
 Re: independant massey fitter needed in south wales u.k in reply to Joe Vazquez, 09-09-2007 09:09:08
just had the workshop manual and the pump is in the bellhousing part and the gearbox is mostly the same as a normal one. the pump is just like a hydraulic pump and spoolvalve in one unit. can you help?
tony vobe
09-09-2007 11:51:09
 Re: independant massey fitter needed in south wales u.k in reply to Case450, 09-09-2007 09:09:08
hi most importantly the shuttle shift is on its way out it gets usless and takes ages to engage when warm if atall
and the 1st gear in hi or low chatters badly so the box needs a rebuild i can remove if pointed in the right direction or order of dismantling but couldnt repair the box.
the power steering is shot.(goes stiff)and there are a lot of bushes and pins need changeing if they need reaming thats out for me.
we bought the machine blind and im sure it has been abused it took me two weeks to replace the grease nipples as they were all blocked.
basically if it was a car i could sort anything but tractors are out.
my old man probably could of but passed away 6 yrs ago so im left to run the farm with my old girl.
i have a large shed with overhead 1 tonne gantry and plenty of light
just need someone that knows what they are looking at
DavidP, South Wales
09-10-2007 01:03:05
 Re: independant massey fitter needed in south wales u.k in reply to tony vobe, 09-09-2007 11:51:09
Hello,
Sorry i can't help you with the shuttle. My experience is agricultural only.
DavidP
richardinnz
09-11-2007 01:06:21
 Re: independant massey fitter needed in south wales u.k in reply to DavidP, South Wales, 09-10-2007 01:03:05
You should be ok David, the shuttle is the same as 2 multi power clutches, they use the same plates as the agri M.P and IPTO clutches.
DavidP, South Wales
09-09-2007 10:00:51
 Re: independant massey fitter needed in south wales u.k in reply to tony vobe, 09-09-2007 09:09:08
Hello Tony,
What is it that you wish to do and to what model?
I live near Bridgend.
Regards
DavidP, South Wales
