MF-35 vs MF-50 exhaust system
Bart CA
09-09-2007 10:53:14
Hi
Does somebody knows why on the MF-35 the exhaust
pipe is connected to the manifold and the muffler
is under the foot board. On the MF-50 the muffler
is under the gas tank near the manifold and the
exhaust pipe is connected after the mufffler.
The engine is the same (Z-134) and both tractors
are identical except for the front end and steering system.
I'm wondering why they were manufactured different
Thanks for reading
Bart
MF Poor
09-10-2007 04:14:14
 Re: MF-35 vs MF-50 exhaust system in reply to Bart CA, 09-09-2007 10:53:14
The 50 was essentially a variant of the 35. (Same engine/tranny/rear end/hydraulics/hitch) In the engineering of the 50, much thought was put in to the row crop version (high arch) crop clearance was a major consideration. The exhaust system was changed to make a vertical exhaust more practical. The down-swept exhaust was an adaptation of the vertical exhaust even though the downswept exhaust probably sold better.
The same line of thought continued through the 135/150 models.
Gerald J.
09-09-2007 13:11:18
Might be they figured the 50 would be worked harder and they didn't want the hot muffler to ignite the crop under it. I know when I had the low muffler on my MF-135, I left strings of glowing bits of corn stalk behind me while plowing. It now has an upright muffler which is good at catching tree limbs.
Gerald J.
