what loader and backhoe is on a u.k mf40 digger?
tony vobe
09-12-2007 10:40:04
i need help identifying the loader and backhoe on my mf40 digger. there is a serial on the backhoe on the valve block but they forgot to stamp the model. i cannot find a serial on the loader maybe missing or cant see it.
the loader i can only say uses the same seat as the driver. it just flips .
and it has vertical legs and rams encased in large square box.
the front loader is the same as most ive seen on here but has self levelling arms above main arms to keep bucket level
are bushes and pins available for either? i have asked earlier but nothing yet.
again this machine has been abused and all pins and bushes badly worn.
i call her elvis as shes the king of rock and roll
any help appreciated
tony vobe
09-13-2007 12:43:22
 Re: what loader and backhoe is on a u.k mf40 digger? in reply to Dale L, 09-12-2007 10:40:04
ill photogreaph elvis later tomorrow. that should help the identification but dont laugh at her its not her fault.
scottwv
09-13-2007 09:03:47
 Re: what loader and backhoe is on a u.k mf40 digger? in reply to tony vobe, 09-12-2007 10:40:04
From your description of the backhoe, it sounds like a model 220
135 Fan
09-13-2007 21:17:28
 Re: what loader and backhoe is on a u.k mf40 digger? in reply to scottwv, 09-13-2007 09:03:47
I think the 220 hoe is a US model and don't know if the UK used the same model or not. The loader is definetly exclusive to UK machines. Dave
135 Fan
09-12-2007 20:07:25
I have a book with a picture of a UK 40 but gives the US description. With vertical stabilizers it should be a side shift backhoe. The loader with self leveling arms and 4 bar linkage is different from the US models but looks like a very good loader. Sorry only have the US model numbers. Hopefully someone else will have more info. You may have to have pins and bushings made but they aren't that big so it shouldn't cost too much. Dave
