MH 08 steel wheel 16row drill settings/info
alex feil
09-15-2007 06:30:56
Howdy, I purchased this MH drill to put in alfalfa and milo food plots for our conservation program. We have repaired/rebuilt this and are ready to go, except. The settings chart does not give the setting for 22lbs of alfalfa per acre. It also does not give milo settings that I can find or read on the chart (it's a little rusty)
Any info or search direction would be greatly appreciated. Thanks inadvance.alex
ChuckBergstrom
09-17-2007 12:22:56
 Re: MH 08 steel wheel 16row drill settings/info in reply to alex feil, 09-15-2007 06:30:56
Hi Alex, Sorry I couldn't be more help. I looked
in a late model drill manual and it still doesn't
list milo. Hoping someone else would jump in.
ChuckBergstrom
09-15-2007 17:48:18
Alex, Do you mean a 308 ??. My chart in the book
does not show Milo or 22 lbs per acre-only 21 and
24 (Alfalfa with Wire Reducer)Cannot respond any
more until sometime monday. Chuck
alex feil
09-16-2007 16:32:27
 Re: MH 08 steel wheel 16row drill settings/info in reply to ChuckBergstrom, 09-15-2007 17:48:18
Hi Chuck, It is a 308 drill. The 3 was under the nut holding the plate on. My plate shows (alfalfa with reducer) on the "small side of the feed wheel" but it only goes up to 6 3/4lb per acre on the 9 tooth sprocket. On the "large side of the feed wheel" chart it lists (left to right) Barley, Oats, Peas and then it is so rusted up I can't read anything. It appears that there is another column listed but I don't know what it is. I'm not sure of what reducer is either and how that would effect the settings. Would you or anyone venture a guess on what catagory milo might work in. Thanks....alex
