MASSEY FERGUSON #10 BALER
MAMAC
09-17-2007 12:32:04
HI MY FATHER HAS A PROBLEM WITH HIS BALER THE PROBLEM IS THE BALER IS NOT TURNING IN THE INSIDE WHERE THE BALES GO IN. SOMETHING BROKEN BEHIND THE GEAR FLUID CAN SOMEONE PLEASE HELP WITH THIS PROBLEM THANK YOU SO MUCHthird party image
ChuckBergstrom
09-17-2007 15:31:57
 Re: MASSEY FERGUSON #10 BALER in reply to MAMAC, 09-17-2007 12:32:04
Hi, Is the baler new to you? Could it be the
shear pin? If it is an older 10 baler with the
large,non hypoid gearbox, the bolts on the large
ring gear inside could be sheared. Was not common
but did happen from time to time. Not difficult
to replace them. Also check the overrunning clutch. Chuck
