MH50 tans fluid
maricopa
09-23-2007 18:21:07
What fluid do I run in the trans, hyd and rear end of my MH50 industrial?
Thank you in advance.
Jeff-oh
09-24-2007 09:10:45
 Re: MH50 tans fluid in reply to maricopa, 09-23-2007 18:21:07
90 Wt. Gear lube is available at NAPA it is Part Number 65-205. 5 gal bucket.
Don-Wi
09-25-2007 00:11:57
 Re: MH50 tans fluid in reply to Jeff-oh, 09-24-2007 09:10:45
But you don't want 90 wt. GEAR LUBE. You want 90 wt. mineral oil if you insist on using the old technology, or use the Perma-Tran III trans/hydraulic fluid.
Regular gear lube will wreck the hydraulic pump in a hurry. Too thick.
Unless the # you posted is for the mineral oil, not regular gear lube, you don't want to use that in any Massey.
Donovan from Wisconsin
Don-Wi
09-24-2007 08:52:49
Back in the day they recommended GL-1 90 wt. mineral oil, it's lioghter than regular 90 wt. gear lube.
Today's modern and better substitute is Massey's Perma-tran III, but you can also run any other fluid that meets Massey's specs (look on the back label)
