MF 12 lawn tractor
9n1411
09-30-2007 18:21:57
Just purchased a MF 12 lawn tractor with attachments - Front snow blower, mower, roto tiller, plow, disc, sprng tooth. Runs good any info app.
Jim L D
10-07-2007 11:10:36
 Re: MF 12 lawn tractor in reply to 9n1411, 09-30-2007 18:21:57
I am woking on one that has sat for several years. And before that some kids messed with it. The problem I have now is trying to determine if it has the proper key switch in it. There are primarly 2 kinds. The one in it now doesn"t seem like the wire location matches up to the switch operation. A matching replacement from NAPA is # 7-01850.Going by the letters next to the terminals on the back of it. Can some one tell me if this is the correct one? The letters are B G L S M Thanks for any and all help.
Briar Creek Stables
10-01-2007 03:56:06
Massey Ferguson 12 Lawn tractor information: Distributor: Massey Ferguson Manufacturer: AMF Model: 12 Type: Lawn & Garden tractor Years produced: - Factory: Original price: Power: Engine: 12 hp [8.9 kW] Engine: Manufacturer: Tecumseh Model: HH120 Fuel: gasoline Cylinders: 1 Bore/Stroke: 3.5x2.875 inches [89 x 73 mm] Displacement: 27.7 ci [454.0 cc] Horsepower: 12 hp [8.9 kW] Cooling: air Compression: Rated RPMs: 3600 Transmission: Type: hydrostatic Forward: infinite Reverse: infinite Mechanical: Chassis: 2WD Steering: Brakes: Lawn Tractor Attachments: Lawn mower: 42 inches [106 cm] Capacity: Fuel: 2.5 gal [9 L] Power Take-off (PTO): Tires: Lawn/turf front: Lawn/turf rear: Dimensions: Weight: Wheelbase: 44 inches [111 cm] Length: 67 inches [170 cm] Width: 35.5 inches [90 cm] Height: 41.75 inches [106 cm] Ground clearance: 7 inches [17 cm]
ChuckBergstrom
09-30-2007 19:25:49
The MF 12 started in 1969 as a hydrostatic drive.
In 1972 was changed to a vari-speed drive. The
plow,disc,and spring tooth were likely made by
Brinley Hardy. We sold these new back then. They
are excellent tractors-I sold one I had last summer to be a puller tractor. Depending on what
trans. in the tractor I should have various books
and material on them. Put it to use-you will have
good luck with it no doubt. Oh, the 620 snow-blow
had two kinds of mountings. Early ones mounted
right on the front bumper-later had a subframe
that went under the tractor. Chuck
JerryCPP(WA)
10-02-2007 19:44:54
 Re: MF 12 lawn tractor in reply to ChuckBergstrom, 09-30-2007 19:25:49
I was working at a Massey Dealer in 1966 and the factory rep brought an MF-12 with hydrostatic to demonstrate. I remember his favorite trick was to go in reverse wide open (The only way to run a hydrostatic) then push the lever forward to burn off a patch in the parking lot, lifting the front wheels off the ground. This was to demonstrate how tough the hydrostatic was. Of course, he took that tractor with him so I never did find out how long it lasted.
Bud Runion
10-17-2007 18:02:30
 Re: MF 12 lawn tractor in reply to JerryCPP(WA), 10-02-2007 19:44:54
I am restoring a MF12 lawn tractor that has been sitting up for several years. I need the headlights and the assemble that holds them in position.
Thx
Bud
