Purpose of wire attached to MF135 Hrydraulic Filter
Brian
11-09-2000 03:18:22
Can anyone shed light on the purpose of the wire that is threaded through the wing nut on the top of the MF135 hydraulic filter and is attached to the pump itself.
I recently changed the hydraulic fluid and filter but had to untwist this wire to be able to twist off the top portion of the hydrualic canister.
After installing the new filter, I reconnected this wire, but can't figure out its purpose. The wire does not appear in any of the parts manual.
Big Dean
11-09-2000 10:54:55
 Re: Purpose of wire attached to MF135 Hrydraulic Filter in reply to Brian, 11-09-2000 03:18:22
That wire is to keep the filter top from unscrewing & coming off. They can do a lot of damage to the pump when they are rolling around in there. I have repaired many of them because that wire was left off.
Brian
11-11-2000 03:02:46
 Re: Re: Purpose of wire attached to MF135 Hrydraulic Filter in reply to Big Dean, 11-09-2000 10:54:55
Thanks, I wondered if that might be the reason. Glad I put it back on!
Jim from Stonepile
11-10-2000 21:38:41
That is what happened to my 135. $460 repair bill, and I took the pumps out and reinstalled them myself.
