Massey Ferguson 3650
Andy B
10-08-2007 11:24:21
I have a Massey 3650 that seems to want to stop moving after about 30 minutes. When the tractor is cold it pulls like an animal, when it gets warmed up it just slowly stops moving. We have replaced the flywheel, clutch and presure plate and computer and it continues to do it. Does anyone have any experience with the Autotronic transmission?
richardinnz
10-11-2007 01:55:36
 Re: Massey Ferguson 3650 in reply to Andy B, 10-08-2007 11:24:21
Check you have the correct pressure in your trans circuit it should be 17bar. Is it Speedshift or Dynashift?
Holm
10-08-2007 16:26:43
It sounds like you might be loosing hyd.pressure for the multi power. ( power shift) Take a pressure test with it cold and see what the pressure is,then take it hot after it has started to slip. It could be the pump or a seal in the clutch pack. If you have run it very long with it slipping you will probably need to replace the multi power clutch disc & plate. It is internal in the trans.
