stuck in gear
Bob Swelland
10-09-2007 15:57:16
Have a Ferguson 35. Sat for afew years. Got it started, runs great, but whoever parked it last, turned off key while in reverse gear. I changed the gear oil, drove around in reverse, but it won't come out of gear. The Hi-Lo range works fine, but still stuck in reverse. Any suggestions?
Big Dean
10-09-2007 16:23:48
 Re: stuck in gear in reply to Bob Swelland, 10-09-2007 15:57:16
Pull your filler plug for the transmission look inside you will see a big gear. Find a level spot shut off the tractor. Push the clutch down & put the high low shifter in neutral to relieve any pressure that might be on the gears. With a long screwdriver or a small pry bar pry the big gear forward if it is hung in reverse. Pry it back if it is hung in first gear. If you happen to go to far it will go in the other gear. You need to get it in the center. You should be able to feel the detent balls pop in the grooves in the shift rail as you move the gear. Through the years I have probably unstuck at least a 1000 of them this way. It is a common problem on the Massey tractors after they get a little wear on them
I have a picture that shows the gear if you need it
