Massey 255 ?????
mountainman61
10-13-2007 06:36:39
Hi Everyone!
I just bought a 255 that I think is a 1975 model. it is missing the exaust manifold and the engine plate can't be read. I'm having a hard time trying to find the right manifold. it goes up through the hood, but there so many different ones when you look them up! How can I identify the engine?
thanks for any help!!
Kelly
mountainman61
10-13-2007 16:25:01
 Re: Massey 255 ????? in reply to Kornfused, 10-13-2007 06:36:39
Thanks Again Dave!!
The one in the photo is like mine....so I have a 203.
that helps me alot in my search for a manifold!!
Thanks, Kelly
mountainman61
10-13-2007 11:47:29
 Re: Massey 255 ????? in reply to Puffie40, 10-13-2007 06:36:39
Thanks Dave!
It is a diesel, but the tag on the intake isn't readable. I was hoping for some easy to spot differences in the engines. Is there something to look for in a 203-v-236?? or a code in the serial# of the tractor?
Thanks, Kelly
DavidP, South Wales
10-13-2007 13:55:17
 Re: Massey 255 ????? in reply to mountainman61, 10-13-2007 11:47:29
Hi again,
How about a couple of little things like the exhaust and starter motor!
The 203 exhaust is on the left and the starter on the right.
The 236 exhaust is on the right and the starter on the left.
Can you see anything of the serial number of the engine at the front left hand side? It may start with '203 UA.....' or 236UA...' for example as they do in the UK with 'U' being made by Perkins in the UK and 'A' to MF spec.
Hope this helps.
David
DavidP, South Wales
10-13-2007 14:05:30
 Re: Massey 255 ????? in reply to DavidP, South Wales, 10-13-2007 13:55:17
Hello,
Go to the bottom 'Content Guide' on this page and into 'Picture List'. On the left hand side of the list you will find a photo of a 255.
DavidP
135 Fan
10-13-2007 09:20:35
 Re: Massey 255 ????? in reply to mountainman61, 10-13-2007 06:36:39
Usually there is a tag on the intake manifold. If not you should be able to tell from the engine serial number or tractor serial number as a last resort. The dealer could tell from the tractor serial number. I assume it's a diesel? If it's a diesel it's either a 203 or 236. A 203 is more likely in a 75 as it's the first year of the 255. The engine serial number will be stamped in the block probably above the injection pump. At least that's where it is on the 3 cylinder. Dave
