I have an MF40 Industrial with MF34 Loader and Davis/Case D-100 backhoe. I finally got this thing running smoothly and had a few questions about the hydraulics:1.) What type of hydraulic fluid does this tractor take? The stuff that is in it has a light brown/carmel color to it. 2.) My dipstick broke off the silly little chain and fell into the MF34 resevoir. Any tips on how to check the fluid level now? Is there any risk of overfilling it? 3.) Is there a recommended RPM to run the tractor at when using the backhoe? The reason I ask is that my dipper cylinder started spewing fluid pretty bad, and my spool assembly starting leaking too. Didn"t know if maybe hyd. pressure is related to engine speed. 4.) What is the recommended tractor setup for backhoe work? (i.e., front bucket down all the way, emergency brake on, transmission in neutral, etc..). I have the manual shuttle shift fwd/rev lever on the left and a 4 speed gearbox with hi and low settings. 5.) Finally, my front left bucket cylinder leaks pretty bad too. Is this something I can repair myself? Is there anything obvious that could be causing the leaking that I should be looking at first? This tractor is a tank, and very powerful. I"d like to get to using it more. Thanks for your help in advance!
