MF 175 Ignition and Charging System
bigtom63
10-25-2007 08:58:04
I have a problem with the charging system. I replaced the alternator on my 175 on advice it was not charging anymore. When battery charged it starts and runs maybe 4 times then starter gets stuck engaged. Get it un struck then charge the battery it goes on another 4 cycles. I also replaced the ignition switch thinking it may be sticking but after replacement the tractor starts with key but will not shut off by key. NEED SOME ADVICE where to go next??
El Toro
10-25-2007 09:26:32
 Re: MF 175 Ignition and Charging System in reply to bigtom63, 10-25-2007 08:58:04
third party image
I think your alternator is back feeding voltage
to your tractor's ignition. You probably need a diode like this one in Bob's picture. Hal
bigtom63
10-25-2007 09:29:12
 Re: MF 175 Ignition and Charging System in reply to El Toro, 10-25-2007 09:26:32
Can you show the whole set up some of the wording in the picture is cut off so I can check this out tonight.
El Toro
10-25-2007 09:50:04
 Re: MF 175 Ignition and Charging System in reply to bigtom63, 10-25-2007 09:29:12
Check your email. Hal
