Pump for loader
CAM
11-16-2000 20:24:32
I am adapting a front end loader for a MF 65. I anticipate that the internal pump will be too slow. Does anyone have suggestions for an auxillary pump? What pressure and flow should I select? Should I use a lovejoy coupling or make a direct drive shaft from the front of the crankshaft? What size tank will I need for the hydraulic fluid? Any suggestions are appreciated.
lee (MN)
11-19-2000 08:09:24
 Re: pump for loader in reply to CAM, 11-16-2000 20:24:32
the pump on your 65 is 4gpm, the front pump is the way to go. I would find a pump in the 6-10 gpm range and a 5-10 gallon tank. the cylinders on your loader will determin the psi of your relief valve, most likly 2000 to 2500 psi. I think you can buy the pump driveshaft from massy but it's spendy. hope this helps
