Massey Harris 22 Rear Axle Bearing
CHARLES TX
11-03-2007 19:53:19
Removed Massey Harris 22 rear axle assembly to work on brakes and replace inner oil seal. The inner axle bearing feels pretty loose. Can this bearing be replaced without removing the differental gears? The bearing looks like it may be pressed on. I have manuals but they do not explain on how to renew the inner bearings. They do say to remove shims to tighten the bearing but not how to replace.
