MF 205 Diesel Oil Pressure Question?
Larry in WNY
11-15-2007 09:45:18
Is it possible to adjust the oil pressure on a Perkins diesel engine? The oil pressure runs near the low end of green on the gauge and I don't have an adapter to put a test gauge on the engine. Also I was wondering if I did get the gauge connected, is there an oil pressure cutout if the switch doesn't detect pressure because the test gauge is connected? On my John Deere the oil pressure can be adjusted with a jam nut, but I haven't read anything like that in the MF manual. Thanks.
Larry
Downeaster
11-20-2007 10:30:51
 Re: MF 205 Diesel Oil Pressure Question? in reply to Larry in WNY, 11-15-2007 09:45:18
Hi Larry, is your a tractor a early 60's MF205 Workbull?
Larry i n WNY
11-20-2007 13:41:49
 Re: MF 205 Diesel Oil Pressure Question? in reply to Downeaster, 11-20-2007 10:30:51
third party image
Yes it's a MF 205 Workbull w/heavy front end loader.
Larry
mf40-me
11-15-2007 19:13:41
I don't know much about an adjustment for the pressure. My hunch is that if there is one it would be on the pump itself, which to get to would mean dropping the pan. In my opinion (which isn't worth much) if you were that far you might as well slide some new bearings in there anyway. Assuming that the bearings are the cause of the low pressure, suppose it could be the pump itself. How many hours on the engine since the last bottom end?
I believe that if you connect a pressure gauge to the line, bypassing the pressure switch, all you will do is keep your alternator from charging for those few minutes which i don't think will harm a thing.
