MF202 dist lube
Brucec
11-15-2007 14:06:30
My owner’s manual says I need to fill the reservoir on my distributer with 20 wt. every 800 hours. If doesn’t say where and I don’t see a place to fill.
Can anyone point me in the right direction?
jb4020
11-15-2007 15:33:05
 Re: MF202 dist lube in reply to Brucec, 11-15-2007 14:06:30
The only place i know of to oil on the distributor is the little oil cap that you put a few drops in.
brucec
12-06-2007 06:23:08
 Re: MF202 dist lube in reply to jb4020, 11-15-2007 15:33:05
According to the owners manual "The distributor has a built in oil reservoir filled with light engine oil and sealed at the factory. Under normal operating conditions, the reservoir should be refilled every 750 hours of operation --- to refill reservoir, remove oil plug and add 20w oil. A small trace of high melt point grease should be placed on the breaker cam every 100 hours of operation. Also place 1 or 2 drops of light (10w) engine oil on the braker lever pivot and 3 to 4 drops on the felt wick under the rotor. I can't find this oil plug and it sure sounds like more than a few drops.
