MF 50 clutch adjustment
CaseyinBG
12-02-2007 10:03:37
I have a 50 that I just put a new clutch in and clutch is not wanting to disengage all the way. I adjusted the pedal, but still won't do right.
DavidP, South Wales
12-02-2007 11:28:45
 Re: MF 50 clutch adjustment in reply to CaseyinBG, 12-02-2007 10:03:37
Hi,
Is it a dual clutch? If so did you carry out the PTO plate and release lever screw adjustments after fitting?
CaseyinBG
12-02-2007 15:04:27
 Re: MF 50 clutch adjustment in reply to DavidP, South Wales, 12-02-2007 11:28:45
It is a dual clutch, but I didn't make any adjustments. The manual talked about a gauge to adjust the release levers to and I haven't been able to find one or atleast a measuerment to adjust to. I took my chances that it would be correct.
Bob N.Y.
12-02-2007 18:38:32
 Re: MF 50 clutch adjustment in reply to CaseyinBG, 12-02-2007 15:04:27
The I&T manual shows the dimentions for the gauge. You can make one from sheet metal or plexiglass. It is very doubtful that you will get that clutch to work properly without doing the pre-installation adjustments.
