information about a massey harris pony.
Zackman1801
12-09-2007 13:06:23
hi, im looking for some information about a massey harris pony tractor. The serial # on the Tractor is PGA16707, im looking into what year the tractor was manufactured, and if the continental engine is the N62 model and if it would take N62 parts since the tractor is going to need some work to allow it to run again.
any input would be helpfull.
thanks
Zack
Zackman1801
12-13-2007 16:25:55
 Re: information about a massey harris pony. in reply to Zackman1801, 12-09-2007 13:06:23
I had another quick question about the tractor, has anyone used it here to Twitch wood out with, i was looking into making this my primary "skidder" untill i hopefully had enough money to buy a real Skidder to do the job.
Zackman1801
12-09-2007 15:46:54
thanks, im going to have to do some maintenance on the motor and other parts since the tractor hasnt run in 5-6 years, although its been kept in decent shape, im probably going to have to take apart the engine though and remove the pistons and soak them, although i mine as well change all the gaskets while im in there, and thats what led me to wondering if the N62 gasket sets would fit?
Vacherie
12-09-2007 14:18:44
S/N 16707 is a 1951.
1953MHMUSTANG
12-09-2007 13:14:33
you can look on this site for your seriel number. you can still engine parts. you shoulndt have any problems finding engine parts. the allis chalmers G uses the same motor and most all of the parts are the same.
Gerald J.
12-09-2007 17:43:46
 Re: information about a massey harris pony. in reply to 1953MHMUSTANG, 12-09-2007 13:14:33
I think all the AC G parts fit except the block which is different for a different starter location. Lots of places with engine parts have parts for the Pony and AC G. There are no sleeves, so if the cylinders are worn they have to be rebored. Oversize pistons and rings are available for that.
Be sure to remove the ridges before pushing the pistons out.
Gerald J.
