MASSEY HARRIS HYDRAULIC LEAKING INTO OIL PAN
popparedstorm
12-18-2007 13:47:43
[ I NEED HELP WITH A PROBLEM OF HYDRAULIC OIL LEAKING INTO THE OIL PAN . I HAVE HAD THE TRACTOR A FEW WEEKS AND FOUND THIS OUT . NEED HELP IN ID OF THE PUMP TO GET A KIT OR BREAK DOWN OF PUMP . PUMP MOUNTS TO FRONT LEFT SIDE ALSO ADD MOTOR OIL AT SAME SPOT . NEW AT THIS TRACTOR GAME . THANKS FROM TEXAS
Login
12-21-2007 20:13:34
 Re: MASSEY HARRIS HYDRAULIC LEAKING INTO OIL PAN in reply to popparedstorm, 12-18-2007 13:47:43
If you never fixed it yet its real simple take your hydraulic pump loose from the tractor & split the pump apart & a 35 cent oring will fix your problem I have done several I noticed mine when the rear seal started leaking because all the htdraulic oil went in there GOOD LUCK & keep the massey legacy going.
MIKE FRENCH
12-18-2007 20:20:36
Need to know model of tractor.
ronnie moss
12-20-2007 18:05:32
 Re: MASSEY HARRIS HYDRAULIC LEAKING INTO OIL PAN in reply to MIKE FRENCH, 12-18-2007 20:20:36
massey harris 44 is all i know thanks
