What have I got 275?
awoods
12-19-2007 15:40:35
I have a tractor that seems to have been made from two diffrent ones. I is marked as 275 serial number 9A275049 motor is A-248. Problem is it shows only to have 6 speed no signe of muti speed ever being on the tranny. I have the tractor split right now rebuilding the engine. It has crossed my mine that maybe they screwed on 3 speed nob and I really have 4 high low can"t really tell with it tore down. Are their any other posibilities? Were their any 6 speeds on any any models that would bolt up?
Powerfarm
12-21-2007 14:29:59
 Re: What have I got 275? in reply to awoods, 12-19-2007 15:40:35
In europe 275 was fitted with 236 engine 248 engine was fitted to 290.
Gear pattern on neighbours 1979 290 and our 1977 590 is: Top row R 3 2 bottom row 1 4 this is a rather illogical pattern as going from 2nd to 3rd is awkward french built 500 series pattern is top R 2 3 bottom 1 4 I've also seen this pattern used on polish and other licence built derivatives of 200 series
chuck bergstrom
12-20-2007 14:25:56
The listed s/n is for a 1977 tractor. That 275
tractor was sold only with a choice of 8 speed
or multi-power trans. The 248 engine is the 275
engine. Later models with the 248 have a diff.
configuration of a s/n. Try your gears,maybe you
have more. Chuck
sibby (aus)
12-20-2007 14:12:40
Down under the 275 had the 236 cu. in. engine. The 248. cu. in. was fitted to the 290 model, maybe different in other countries. cheers.
TomTex
12-19-2007 21:32:50
Cant say on your 275. I have the MF-690 which replaced the 275. It also has the Perkins 248 in it. I have 3 shift sticks. One is 1-2-3-R, next is rabbit and turtle, next is low start High. In other it has 12 forward speeds and 4 reverse speeds from the 3 sticks. Tom
MF#1
12-19-2007 18:11:02
FWIW, seems to be a 1977 serial number. The 4speed pattern is: Top- Rev-4-2 Bottom-1-3. Don"t know if a MP was available on the 275/265/255.
Don-Wi
12-20-2007 00:15:33
 Re: What have I got 275? in reply to MF#1, 12-19-2007 18:11:02
If the Multi-power was available on the older and smaller 165's and 135's, you bet it woulda been available on the 255, 265, and 275's.
Donovan from Wisconsin
