135 ax. two spool hudraulic value how it works?????
archie KY
12-21-2007 17:15:34
I have two spool ax. hydraulic for my 135 thats bolts under the seat. Just wondeing how it works. Any one have this set up Please let me know.Thankis Archie
135 Fan
12-21-2007 18:03:57
 Re: 135 ax. two spool hudraulic value how it works????? in reply to archie KY, 12-21-2007 17:15:34
There are several different types of valves on MF tractors. Look in the archives on here. Look on the Puddingsworld web site under other MF tractor sites. At the bottom of the list is a manual for a bunch of MF tractors. It is the manual that explains the aux. hyd. valves in detail. Dave
Gerald J.
12-21-2007 17:45:54
It bolts in place of a plate with a hydraulic passage in it. The left spool controls the three point up or down with a center position that enables the right hand spool that gets hooked to the remote cylinder. The original three point controls have to be full up (constant pumping position) for the remote cylinder to work. The left spool handle when pulled back lowers the three point. Locks the three point in the mid position where it enables the right hand spool. In the front position, it lifts the three point if the original controls are in the constant pumping position, otherwise in that position it lets the original position and draft controls work like they did before the auxiliary valve was added.
Gerald J.
