275 pulling
awoods
12-25-2007 18:11:21
What is a good size disk the 275 will handel well? Without working harder than you should. I am refearing two a good heavey leveling style not offset but a good cuting one. I have a 5 1/2 offset I will use when I need offset I know it will handel it with ease with 20" disk. I was thinking around a 9 what is right Massy experts?
I know quite a few people say some of the hp rating are under on some of the MF. Does the 275 fall into this catagory? Mine is the model with the external balancer.
Also can anyone tell me why the 290 with the same 248 engine is rated with less hp?
ramtuff
12-26-2007 16:56:30
 Re: 275 pulling in reply to awoods, 12-25-2007 18:11:21
I have a 255 always pulled 12'ihc wheel disk/cultipacker&drag in black ground or hilly maid dirt no problems,have got the fuel turned up.
awoods
12-26-2007 15:53:16
Thanks for the imput can't wait to get her going in a few weeks. Still having problems finding a good salvage yard for the whole swing draw bar. All in my area have it but are too proud of it. Im in South Carolina.
MF#1
12-26-2007 12:55:13
Pulled a 9 footer with an MF 255 for years, still have it, no problems. Yours will pull it easy, may even get a larger one with not much trouble.
El Toro
12-26-2007 05:51:07
I would use the 8-foot disk. Hal
TomTex
12-25-2007 19:07:12
I have a MF-690 which replaced the MF-275, uses the same Perkins 4-248. I pull a 7 1/2 foot offset disk, and pull an 8 foot tandem disk. Could probably pull a 10 foot tandem if I had one, but the 8 foot pulls good. Tom
