power adjust rims
Arch
01-03-2008 16:33:39
Has anyone ever cut the rails from a power adjust and welded them back in aother rim . The 6 loop rims are $144.00 and the power adjust is $375.00. And if you have how did you do it??? Thank Archie
Dean
01-04-2008 09:12:49
 Re: power adjust rims in reply to Arch, 01-03-2008 16:33:39
Arch:
I know of no one who has done this with the common MF/AC type power adjust rims but it has been done with the (no longer available anywhere) vintage Ford power adjust rims.
It looks to be a more difficult job to do this on the Ford design rims so it clearly ought to be possible to do so with the MF/AC rail type rims.
I have been told that it is a tedious, time consuming process to do this with Ford power adjust rims.
Used MF PA rims of this design should not be hard to find.
Dean
Aaron Ford
01-04-2008 09:05:47
Most wheel damage I have seen is corrosion from CACL leakage. I reversed my rims so that the damaged/welded area would not show. I am interested in seeing if the rails could be removed and reinstalled also.
Thanks
Aaron
DavidP, South Wales
01-04-2008 01:02:53
If your rims are worn in one place and you don't need full adjustment capability you can change the rims side for side. It will alter wheel track, but its cheaper.
