Re: MF 175 Key Switch
Tom Dold
01-04-2008 09:47:48
bigtom63
It depends if the tractor is gas or diesel or if the tractor was originally equipped with a generator or an alternator. They were equipped with either depending on serial #. If a later style Delcoe (self contained regulator) alterntor was put on a gas tractor the excite wire must have a blocking diode to prevent the alternator from feeding back to the ignition coil. If it doesn't the engine will not shut down and depending where the excite wire is being fed from could cause the starter solenoid to engage.
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349 605-772-4541
dold@alliancecom.net
bigtom63
01-04-2008 10:07:58
 Re: MF 175 Key Switch in reply to Tom Dold, 01-04-2008 09:47:48
First off it is gas and I replaced the alt/gen by using the number on the old unit and converting it to a newer number. If I get the new part number can you tell me what I may have to do or is their a easy way to test measure somewhere I do have a digital multimeter
